Health status
MetaShare depends on the service health of Microsoft 365 and Azure. You can also get updates on Microsoft’s health status from Twitter (@MSFT365Status).
If there are no ongoing problems with Microsoft 365 and your problem is not listed here, check our known issues.
Ongoing issues
  • Recent documents include only one document
    Start time: 12 November 2025
    Updated: 17 December 2025
    Microsoft has recently deprecated Graph endpoint used for retrieving recent documents which is used by MetaShare. Usually, deprecated endpoints continue to work for some time, giving developers time to update APIs they use. Unfortunately in this case, according to Microsoft, the recent endpoint will continue to work in a degraded state, which appears to mean retrieving only one item. We are working on an update using different APIs to resolve the issue.
Resolved issues
  • SharePoint issue: Recently mapped crawled properties are not displayed in Admin Center
    Start date: 9 June 2026
    Resolved: 31 July 2026
    When mapping crawled properties to managed properties (e.g. RefinableString) in the SharePoint Admin Center the mapping is not displayed after changes are saved. We were able to confirm that the mapping is persisted and managed properties are populated with values from added crawled properties, even if the Search Schema UI doesn’t show the mapping.
    While this does not affect the functionality of MetaShare directly, we are getting reports and questions about the issue from MetaShare administrators. We have reported our findings to Microsoft but they reported that no issue was found. We continue monitoring the situation.
    Update: 18 June 2026
    Microsoft has now acknowledged the issue and it can be followed in Microsoft 365 admin center (issue SP1393483)
  • Guest users can’t see managed metadata values
    Start time: February 2026
    Published: 9 March 2026
    Guest users in some tenants stopped seeing metadata values (terms) set on documents which they have access to. The issue affects not only MetaShare, but SharePoint sites as well. We’re in contact with Microsoft regarding the issue. It seems that a recent change in SharePoint changed how values are retrieved from Taxonomy Hidden List. Current solution/workaround seems to be adding guest users to a group that has read permissions on Taxonomy Hidden List.
    Update: 11 March 2026
    The issue seems now to be resolved by Microsoft. We’ll continue monitoring the issue and verify if the fix reached all affected tenants.
More
All resolved issues
